abaqus 计算中的问题,请高手帮忙解答
浏览:184005 回答:1
因为是刚开始学习设abaqus模型,计算的时候出现出现了一些问题,不知道怎么修改,请大虾们帮忙解决一下,现把出错误的文件贴出来,帮忙看下并予解答.材料厚度都附好了,为什么会出现下面的问题?
***ERROR: NO SURFACE FACETS ARE GENERATED FOR SURFACE CONTACT1_S.
*SURFACE, NAME = contact1_m, TYPE = ELEMENT
*SURFACE, NAME = contact1_s, TYPE = ELEMENT
*SURFACE INTERACTION, NAME = interfaces
*CONTACT PAIR, INTERACTION=interfaces, ADJUST=0.08, SMOOTH=0.2
***ERROR: THE SLAVE SURFACE CONTACT1_S DOES NOT EXIST.
*MATERIAL, NAME=PA66-GF35
*DENSITY
*ELASTIC, TYPE = ISOTROPIC
*PLASTIC
*MATERIAL, NAME=steel
*DENSITY
*FRICTION
*SOLID SECTION, ELSET=solid, MATERIAL=steel
*SOLID SECTION, ELSET=lvl2_solid, MATERIAL=steel
*SOLID SECTION, ELSET=ball_solid_1, MATERIAL=PA66-GF35
*SHELL SECTION, ELSET=solid, MATERIAL=steel
*SHELL SECTION, ELSET=ball_steel, MATERIAL=steel
*SHELL SECTION, ELSET=lvl2_solid, MATERIAL=steel
*SHELL SECTION, ELSET=ball_solid_1, MATERIAL=PA66-GF35
*BOUNDARY
*MPC
***ERROR: THE SHELL THICKNESS MUST BE PROVIDED FOLLOWING THE *SHELL SECTION
OPTION
*DENSITY
*PLASTIC
*DENSITY
*FRICTION
*BOUNDARY
*MPC
OPTION
