新手请教patran求解失败问题
浏览:194073 回答:1
刚开始学习patran,遇到了个问题,请教一下
按照教程建好模后,再按analysis
在Analysis Manager中出现如下情况:
<1> SOFTWARE\MSC.Software Corporation\MSC.AnalysisMgr\2004.0.3
<2> SOFTWARE\MSC.Software Corporation\MSC.AnalysisMgr\2004.0.3
<3> SOFTWARE\MSC.Software Corporation\MSC.AnalysisMgr\2004.0.3
<4> SOFTWARE\MSC.Software Corporation\MSC.AnalysisMgr\2004.0.3
<5> license checked out
<6> Attempting to connect to the QueMgr on PC-200903021239:1900 ...
<7> Connection with QueMgr Established
<8> Established configuration using path = 'D:\MSC.Software\MSC.Patran\2004\p3manager_files' on queue machine 'PC-200903021239', port '1900'
<9> Filling data from JobControlView
<10> Filling data from ResourcesView
<11> Filling data from GeneralView
<12> Filling data from MiscView
<13> Filling data from RestartView
<14> Wait! Submitting job <plate_static>
<15> Error Returned 1 Error starting JobMgr on local host, code = -4 Errmsg = JobMgr_ERROR -308 argc=14 argv=<1 PC-200903021239 1900 plate_static 8 Administrator D:/MSC.Software/work files 0 1242208031 MSC.Nastran nast2004 2004.0.3 >
<16> Error in reading .mon file ('UNKNOWN/plate_static.mon') for job 'plate_static (8) (UNKNOWN)'. Error: 'Error, unable to open mon file <UNKNOWN/plate_static.mon>, error = 3
<17> Error in reading .mon file ('UNKNOWN/plate_static.mon') for job 'plate_static (7) (UNKNOWN)'. Error: 'Error, unable to open mon file <UNKNOWN/plate_static.mon>, error = 3
<18> Error in reading .mon file ('UNKNOWN/plate_static.mon') for job 'plate_static (6) (UNKNOWN)'. Error: 'Error, unable to open mon file <UNKNOWN/plate_static.mon>, error = 3
<19> Error in reading .mon file ('UNKNOWN/plate_static.mon') for job 'plate_static (5) (UNKNOWN)'. Error: 'Error, unable to open mon file <UNKNOWN/plate_static.mon>, error = 3
<20> Error in reading .mon file ('UNKNOWN/model01.mon') for job 'model01 (4) (UNKNOWN)'. Error: 'Error, unable to open mon file <UNKNOWN/model01.mon>, error = 3
<21> Error in reading .mon file ('UNKNOWN/plate_static.mon') for job 'plate_static (3) (UNKNOWN)'. Error: 'Error, unable to open mon file <UNKNOWN/plate_static.mon>, error = 3
<22> Error in reading .mon file ('UNKNOWN/plate_static.mon') for job 'plate_static (2) (UNKNOWN)'. Error: 'Error, unable to open mon file <UNKNOWN/plate_static.mon>, error = 3
<23> Error in reading .mon file ('UNKNOWN/plate_static.mon') for job 'plate_static (1) (UNKNOWN)'. Error: 'Error, unable to open mon file <UNKNOWN/plate_static.mon>, error = 3
请问是怎么回事啊
沙漠绿洲_5119
这种情况,自己最好重新做一下。刚开始做例子总会碰到很奇怪的问题,多做几次就好了
2009年5月24日
