首页
学院
直播
问答
悬赏
全部悬赏
发布悬赏
专家入驻
会议
社区
CAE工程师认证
CAE服务
搜索
发布
注册
登录
求abaqus塑性损伤模型理论
浏览:191199
回答:9
我想了解abaqus塑性损伤模型的基本理论,希望有这方面资料的大侠能够提供一下,谢谢!
ABAQUS
CAE
结构CAE
DYNAFORM中的模具方向问题
给单直管通上流体进行振动分析是属于流体分析的内容嘛
关注问题
邀请回答
我来回答
(9)
默认
最新
引用的文献
脉动压力作用下直埋式蜗壳非线性动力响应
2009年6月21日
评论
点赞
adayard
引用的文献能说一下吗?还有就是想请问下对于混凝土的塑性损伤模型里面怎么定义破坏准则?混凝土一直变形下去吗?
2009年6月17日
评论
点赞
tndbhui
呵呵,回复相当的繁杂啊
2009年5月24日
评论
点赞
sunhaiqingyan
谢谢了,你提供的资料相当有参考价值。
2009年5月24日
评论
点赞
winken
不错,要是再加上点损伤材料模型的理论解释就更完美了
2009年5月23日
评论
点赞
*MATERIAL,NAME=CONMAT1
*ELASTIC
19715,0.18
*DENSITY
2400.0E-12
*CONCRETE DAMAGED PLASTICITY
15.0,
*CONCRETE COMPRESSION HARDENING
7.899434265,0
8.847110164,0.000175783
11.17810984,0.000275783
13.24986658,0.000375783
16.71535726,0.000575783
19.41953734,0.000775783
22.35449259,0.001075783
24.26961665,0.001375783
25.11983211,0.001575783
25.58021108,0.001725783
25.91360916,0.001875783
26.31796594,0.002275783
26.33228573,0.002375783
26.31900129,0.002475783
26.22113814,0.002675783
25.80613603,0.003075783
25.02006231,0.003575783
23.46491194,0.004375783
22.42694577,0.004875783
20.3684549,0.005875783
18.43135199,0.006875783
16.65434271,0.007875783
15.04000765,0.008875783
13.57904678,0.009875783
12.25888531,0.010875783
10.5147091,0.012375783
9.395310541,0.013475783
9.018490403,0.013875783
7.349298322,0.015875783
5.98903889,0.017875783
4.880544392,0.019875783
*CONCRETE TENSION STIFFENING, TYPE=DISPLACEMENT
2.633228573,0
2.633228573,0.005
2.633228545,0.008
2.633225696,0.01
2.632431905,0.015
2.62324421,0.02
2.592586718,0.025
2.535224361,0.03
2.455078564,0.035
2.359582811,0.04
2.255839549,0.045
2.14929601,0.05
2.043679667,0.055
1.941341525,0.06
1.843644551,0.065
1.751283285,0.07
1.664517917,0.075
1.583336307,0.08
1.50756258,0.085
1.436928382,0.09
1.371118819,0.095
1.309801524,0.1
1.252644607,0.105
1.199327356,0.11
1.149546229,0.115
0.878903008,0.15
0.641901032,0.2
0.400393304,0.3
0.282476506,0.4
0.21433908,0.5
0.170610981,0.6
0.140472322,0.7
0.118599361,0.8
0.102092699,0.9
0.089248775,1
cemichaelliu 定义的本构关系之一
2009年5月23日
评论
点赞
ompression behavior:
Stress Inelastic strain Damage Inelastic strain
24.019E+6 0.0000 0.0000 0.0000
29.208E+6 0.0004 0.1299 0.0004
31.709E+6 0.0008 0.2429 0.0008
32.358E+6 0.0012 0.3412 0.0012
31.768E+6 0.0016 0.4267 0.0016
30.379E+6 0.0020 0.5012 0.0020
28.507E+6 0.0024 0.5660 0.0024
21.907E+6 0.0036 0.7140 0.0036
14.897E+6 0.0050 0.8243 0.0050
2.953E+6 0.0100 0.9691 0.0100
Tension recovery factor = 0.0. Tension behavior:
Stress Cracking strain Damage Cracking strain
1.780E+6 0.0000 0.0000 0.0000
1.457E+6 0.0001 0.3000 0.0001
1.113E+6 0.0003 0.5500 0.0003
0.960E+6 0.0004 0.7000 0.0004
0.800E+6 0.0005 0.8000 0.0005
0.536E+6 0.0008 0.9000 0.0008
0.359E+6 0.0010 0.9300 0.0010
0.161E+6 0.0020 0.9500 0.0020
0.073E+6 0.0030 0.9700 0.0030
0.040E+6 0.0050 0.9900 0.0050
2009年5月23日
评论
点赞
sunhaiqingyan
我需要的就是混凝土的塑性损伤模型,并且希望能够在相关参数的选取上有所了解,谢谢了!
2009年5月20日
评论
点赞
你要看你算的什么材料了,我有些混凝土材料的数据,
2009年5月18日
评论
点赞
推荐阅读
COMSOL中实现煤层瓦斯运移系列课程
康康学长
¥199
人工智能工程应用实例: 发动机排放数据学习及预测
IDAJ中国
¥99
有限元理论之等参单元教程
引垂思汀
¥20
Altair二次开发答疑&典型案例解读
ALTAIR
¥10
基于workbench钢板弹簧的有限元分析(强度与变形)
lz1234
¥80
汽车仪表模具模流分析的实战讲解
北卡
免费
HBM应变测量基础
HBK测试与测量
免费
5G终端天线仿真设计方法及其应用
Ansys中国
免费
测量不确定度的应用实践
HBK测试与测量
免费
混合动力市场及技术趋势分析
陈开
免费
ANSA二次开发-Python基础入门
筱九
¥30
Adams Car 扭力梁悬架模型的搭建视频
仿真分析
¥19.8
基于abaqus的部分钢骨混凝土框架梁柱边节点有限元分析
T10
¥150
喷嚏中的学问——病毒飞沫传播方式的CFD 仿真
海克斯康设计与仿真
免费
* starccm+制动盘旋转-冷却仿真(主体更新完成)
qqsww
¥199
0#块箱梁托架法施工结构模拟
yudachuan1105
¥200
向量微积分理论基础
引垂思汀
¥50
Abaqus接触类分析(凹陷)一键建接触(简单的一笔)附demo
北斗七星仿真工作室
¥5
ABAQUS任意梁单元截面的实现
eFEA
¥100
基于OptiSturct的线性静力学分析和尺寸优化
Leon_sun
¥10
工程师
必备
项目客服
培训客服
平台客服
脉动压力作用下直埋式蜗壳非线性动力响应
