内存256能装abaqus吗?
浏览:85775 回答:2
我的笔记本较老,内存256,能装abaqus吗?
tianjian
256M 是没有问题的了,但是不能运算大的程序了,小模型都能算的。
2009年7月4日
winken
原帖由 zhanglepin 于 2009-6-11 9:52:00 发表
装是能装,但是用起来很困难,根据ABAQUS帮助文档的建议,电脑内存至少配1GB,如下所示:
A minimum of 1 GB of free physical memory is required to run Abaqus; at least 2 GB of free physical memory is recommended for adequate performance. If Abaqus is page faulting excessively, additional memory will reduce the page-fault rate, as well as the execution time. The requirements are highly job dependent. Abaqus will perform better if more memory is available; to run large problems, significantly more memory than the minimum is required
2009年6月11日
