有关荷载步的疑问
浏览:190331 回答:4
*** WARNING *** CP = 18.906 TIME= 17:17:56
File 081130.s01 does not exist.
The LSREAD command is ignored.
*** WARNING *** CP = 19.078 TIME= 17:17:56
File 081130.s02 does not exist.
*** WARNING *** CP = 19.141 TIME= 17:17:56
File 081130.s03 does not exist.
请问怎么处理
(4)
Mars
还需要另外设置么?我刚开始弄还不懂。担心同一个节点的荷载覆盖,所以用了荷载步结果出了问题
2009年8月31日
邹正刚
执行 Lsread 时的 Jobname 是 "081130" 吗?
2009年8月31日
Mars
!荷载步设置
OUTRES,ALL,ALL
AUTOTS,OFF
TIME,1
NSUBST,10
ACEL,,9.8 !施加自重
ISWRITE,1
TIME,2
NSUBST,10
!施加截面内力
F,28746,FZ,0 !施加轴力
F,28749,FZ,0
F,28746,FY,-27646/2 !施加剪力
F,28749,FY,-23112/2
ISWRITE,2
TIME,3
NSUBST,20
!降温法施加预应力
ALLSEL,ALL
CMSEL,S,HTD
BFL,ALL,TEMP,-1302E6/1.2E-5/1.95E11
ALLSEL,ALL
CMSEL,S,STD
BFL,ALL,TEMP,-785E6/1.2E-5/2.06E11
BFTRAN
ISWRITE,3
!施加预应力完毕
具体一点问题在哪里?
2009年8月30日
bme
lswrite,1?有没有写入载荷步?参考下面的例子,一个拓扑优化的例子
/TITLE, A 2-D, multiple compliance minimization problem subjected
to volume constraint
/PREP7
BLC4,0,0,3,1 ! Create solid model (3 x 1 rectangle)
ET,1,82 ! Use 2-D solids. Type 1 is optimized
ET,2,82 ! Type 2 is not optimized.
MP,EX,1,118E9 ! Linear isotropic, material
MP,NUXY,1,0.3
ESIZE,0.05 ! Use a relatively fine mesh density
TYPE,1
AMESH,ALL ! Free, rectangular-element meshing
NSEL,S,LOC,X,0,0.4 ! Select region not to be optimized
ESLN
TYPE,2
EMODIF,ALL ! Define type 2 elements
ALLSEL
NSEL,S,LOC,X,0
D,ALL,ALL,0 ! Fixed at X = 0
NSEL,S,LOC,X,3
D,ALL,ALL,0 ! Fixed at X = 3
FORCE = 1000 ! Value for applied load
NSEL,S,LOC,X,1
NSEL,R,LOC,Y,1
F,ALL,FY,FORCE ! Define first load case
ALLSEL
LSWRITE,1 ! Write first load case
FDEL,ALL
NSEL,S,LOC,X,2
NSEL,R,LOC,Y,0
F,ALL,FY,-FORCE ! Define second load case
ALLSEL
LSWRITE,2 ! Write second load case
FDEL,ALL
TOCOMP,MCOMP,MULTIPLE,2 ! Define multiple compliance function
! "MCOMP" for topological optimization
TOVAR,MCOMP,OBJ ! Define "MCOMP" as topological objective
TOVAR,VOLUME,CON,,50 ! Define "VOLUME" as topological constraint; 50 percent
volume reduction
TOTYPE,OC ! Specify solution approach
TODEF ! Initialize topological opt.
/SHOW,topo,grph ! Put graphics in a file (remove if interactive)
/DSCALE,,OFF
/CONTOUR,,2
TOLOOP,12,1 ! Perform no more than 12 iterations
FINISH
TOGRAPH,OBJ ! Graph final objective (compliance) history
TOGRAPH,CON ! Graph final constraint (volume) history
TOPRINT,OBJ ! Print final objective (compliance) history
TOPRINT,CON ! Print final constraint (volume) history
*GET,TITER,TOPO,,ITER ! Get iteration counter
*GET,OCMP,TOPO,TITER-1,TOHO ! Get final compliance value
2009年8月30日
