爆破仿真求助
浏览:141061 回答:2
*E0S_JWL
Check near line # 13
(This is line# 381 of file
C:\DOCUME~1\ADMINI~1\BLASTI~1.K)
*** Warning The following lines will be skipped:
1. 1 229.0 0.55 6.5 1.00 0.35 3.51
expanding memory to 270320
*** Error input data failed with: 1 errors
做了一个二维的爆破模型,运行的时候出现这个错误,高手帮我看一下,难道是参数错了?我用的单位是MM-KG-MS,229、0.55的单位都是GPA。谢谢了~~~
