这个例子有问题,运行显示:an invalid file name was specified!!
浏览:179790 回答:2
!(1)分析环境设置
/FILNAME,PRACTICE
/TITLE,DROP OF A HOLLOW BALL
!(2)进入前处理器,定义单元类型、单元选项以及参数
/PREP7
ET,1,SHELL163
KEYOPT,1,1,6
*SET,_RC_SET,1,
R,1
!(3)建立材料模型
!建立一个完全固定的刚体材料模型
RMODIF,1,1, , ,2.5e-3, , , ,
EDMP,RIGI,1,7,7
MP,DENS,1,7800
MP,EX,1,2e11
MP,NUXY,1,0.3
!建立2号材料模型为双线性弹塑性模型
MP,DENS,2,2600
MP,EX,2,7e10
MP,NUXY,2,0.33
TB,BKIN,2,,,,
TBDAT,1,3.5e7
TBDAT,2,1.35e8
!(4)直接建立刚性平面的有限元模型
N, ,-0.6,0.0,-0.6,,,,
N, , -0.6,0.0,0.6,,,,
N, ,0.6,0.0,0.6,,,,
N, ,0.6,0.0,-0.6,,,,
E,1,2,3,4
!(5)建立空心球壳的几何模型并进行网格的划分
SPH4,0.0,0.3,0.06
VDELE,1
AATT,2,1,1
AESIZE,ALL,0.03
AMESH,ALL
!(6)在球壳表面和刚性平台之间建立面对面自动接触
NSEL,S,LOC,Y,0.1,0.5
CM, SPHERE,NODE
ALLSEL ALL
NSEL,S,LOC,Y,-0.1,0.1
CM, TABLE,NODE
ALLSEL ALL
EDCGEN,ASTS,SPHERE,TABLE,0,0,0,0,0, , , , ,0,10000000
!施加初始速度
EDVE,VELO,SPHERE,0,-5.05,0,0,0,0, , , , , ,
!建立时间以及加速度数组并赋值
*DIM,TIME,ARRAY,2,1,1, , ,
*DIM,GY,ARRAY,2,1,1, , ,
*SET,TIME(1,1,1) ,0.0
*SET,TIME(2,1,1) ,1.0
*SET,GY(1,1,1) ,9.8
*SET,GY(2,1,1) ,9.8
!用EDLOAD命令来施加ACLY载荷
EDLOAD,ADD,ACLY,0,SPHERE,TIME,GY, 0, , , , ,
FINISH
/SOL
TIME,0.5,
EDRST,50,
EDHTIME,30,
EDDUMP,1,
EDENERGY,1,1,1,1
solve
/FILNAME,PRACTICE
/PREP7
ET,1,SHELL163
KEYOPT,1,1,6
*SET,_RC_SET,1,
R,1
!(3)建立材料模型
!建立一个完全固定的刚体材料模型
EDMP,RIGI,1,7,7
MP,DENS,1,7800
MP,EX,1,2e11
MP,NUXY,1,0.3
!建立2号材料模型为双线性弹塑性模型
MP,DENS,2,2600
MP,EX,2,7e10
MP,NUXY,2,0.33
TB,BKIN,2,,,,
TBDAT,1,3.5e7
TBDAT,2,1.35e8
!(4)直接建立刚性平面的有限元模型
N, ,0.6,0.0,0.6,,,,
E,1,2,3,4
SPH4,0.0,0.3,0.06
VDELE,1
AATT,2,1,1
AESIZE,ALL,0.03
AMESH,ALL
CM, SPHERE,NODE
ALLSEL ALL
CM, TABLE,NODE
ALLSEL ALL
!施加初始速度
!建立时间以及加速度数组并赋值
*SET,GY(1,1,1) ,9.8
*SET,GY(2,1,1) ,9.8
!用EDLOAD命令来施加ACLY载荷
FINISH
/SOL
TIME,0.5,
EDRST,50,
EDHTIME,30,
EDDUMP,1,
EDENERGY,1,1,1,1
solve
