高手帮忙看看,调试都没问题,计算的时候LS970报错!(附上K文件,交流一下)
浏览:97053 回答:2
E:\学习\研究生学习\LSDYNA模型\BLASTING>echo off
Date: 03/11/2010 Time: 11:32:23
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 01/10/2005 |
| Revision: 5434a Time: 18:01:01 |
| Features enabled in this version: |
| ANSYS Database format |
| Shared Memory Parallel |
| Licensed to: |
| Platform : |
| OS Level : WINDOWS XP |
| Hostname : damir |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: E:\学习\研究生~1\LSDYNA~1\BLASTING\BLASTING.k
The native file format : 32-bit small endian
Memory size from command line: 64000000
on UNIX computers note the following change:
ctrl-c interrupts ls-dyna and prompts for a sense switch.
type the desired sense switch: sw1., sw2., etc. to continue
the execution. ls-dyna will respond as explained in the users manual
type response
sw1. a restart file is written and ls-dyna terminates.
sw2. ls-dyna responds with time and cycle numbers.
sw3. a restart file is written and ls-dyna continues calculations.
sw4. a plot state is written and ls-dyna continues calculations.
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2005 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
input of data is completed
initial kinetic energy = 0.00000000E+00
initialization completed
dt of cycle 1 is controlled by solid element 54000
time........................... 0.00000E+00
time step...................... 2.46705E-01
kinetic energy................. 0.00000E+00
internal energy................ 9.70381E+00
spring and damper energy....... 1.00000E-20
hourglass energy .............. 0.00000E+00
system damping energy.......... 0.00000E+00
sliding interface energy....... 0.00000E+00
external work.................. 0.00000E+00
eroded kinetic energy.......... 0.00000E+00
eroded internal energy......... 0.00000E+00
total energy................... 9.70381E+00
total energy / initial energy.. 1.00000E+00
energy ratio w/o eroded energy. 1.00000E+00
global x velocity.............. 0.00000E+00
global y velocity.............. 0.00000E+00
global z velocity.............. 0.00000E+00
cpu time per zone cycle............ 0 nanoseconds
average cpu time per zone cycle.... 0 nanoseconds
average clock time per zone cycle.. 2833 nanoseconds
estimated total cpu time = 0 sec ( 0 hrs 0 mins)
estimated cpu time to complete = 0 sec ( 0 hrs 0 mins)
estimated total clock time = 1240 sec ( 0 hrs 20 mins)
estimated clock time to complete = 1240 sec ( 0 hrs 20 mins)
1 t 0.0000E+00 dt 2.47E-01 flush i/o buffers
1 t 0.0000E+00 dt 2.47E-01 write d3plot file
请按任意键继续. . .
zxcq06
我遇到过这种情况,是电脑突然蓝屏再进行重启动的时候就这样,也没有错误,这应该是软件的问题。如果你没有蓝屏,死机意外情况的发生,就完全重启动一次,再不行就重装软件应该可以解决。
2011年12月2日
chenxin168
不好意思 这个不是很懂
2010年3月20日
