关于dynaform单动拉延设置的问题 期待解决
浏览:62134 回答:4
刚学习dynaform两礼拜,装的是dynaform5.6版本,一个问题困绕了好几天,始终找不到原因
使用自动设置 单动设置做圆筒件的拉深成型模拟 其中blank是通过毛坯尺寸估算再用毛坯生成器得到
die是导入的igs文件面网格化后得到 die的尺寸:圆筒直径31mm 高20mm 倒角半径2mm
自动设置参数大部分取的默认值 提交任务管理器后能计算 计算status出现aborted
尝试很多次都这样 期待高手解决!
message:
node # 30 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
5248 t 5.8298E-03 dt 9.00E+05 write d3plot file
E r r o r t e r m i n a t i o n
s t o r a g e a l l o c a t i o n
Memory required to complete solution : 3888395
Additional dynamically allocated memory: 127285
Total: 4015680
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 1.7000E+01 13.39 1.6265E+01 12.77
Element processing ... 7.0000E+01 55.12 6.8237E+01 53.57
Binary databases ..... 1.0000E+00 0.79 1.5800E-01 0.12
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 3.8000E+01 29.92 4.2381E+01 33.27
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 1.0000E+00 0.79 3.3300E-01 0.26
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 1.2700E+02 100.00 1.2737E+02 100.00
Problem time = 5.8298E-03
Problem cycle = 5248
Total CPU time = 127 seconds ( 0 hours 2 minutes 7 seconds)
CPU time per zone cycle = 1547 nanoseconds
Clock time per zone cycle= 1562 nanoseconds
Number of CPU's 1
NLQ used/max 96/ 96
Start time 08/10/2010 15:48:19
End time 08/10/2010 15:50:28
Elapsed time 129 seconds( 0 hours 2 min. 9 sec.) for 5248 cycles
尝试很多次都这样 期待高手解决!
message:
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
Total: 4015680
Number of CPU's 1
NLQ used/max 96/ 96
王毅
