请教查看结果,弹出The result file "file.RST" may have been
浏览:156439
我做了非线性分析之后想进入/post26进行后处理
点击TimeHist Postpro之后老是弹出一个东西
Result File Mismatch
The result file "file.RST" may have been solved using different model data than
currently stored. Results may be erroneous. Do you want the database cleared?
怎么会弹出这个那?选择No,可以继续,但是结果同以前的一样。
选择yes就把原来设定的参数都清除了?
请问怎么解决
谢谢!!
