感应加热分析时报错"Parameter _Z needs subscripts "的解决之法
浏览:151752 回答:3
各位大侠在用ansys分析 电磁炉感应加热分析时,在MFS Define时出现“Parameter _Z needs subscripts ”的报错而无法解决,望与各位讨论解决之道!谢谢!
以下是我的命令流:
/PREP7
ET,1,SOLID97
ET,2,SOLID97
ET,3,SOLID97
ET,4,SOLID97
ET,5,SOLID70
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,1,,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,730
MPTEMP,3,930
MPTEMP,4,1000
MPDATA,KXX,2,,60.64
MPDATA,KXX,2,,29.5
MPDATA,KXX,2,,28
MPDATA,KXX,2,,28
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EMIS,2,,0.68
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,27
MPTEMP,3,127
MPTEMP,4,327
MPTEMP,5,527
MPTEMP,6,727
MPTEMP,7,765
MPTEMP,8,765.001
MPTEMP,9,927
MPDATA,ENTH,2,,7.8886e-31
MPDATA,ENTH,2,,9.1609056e7
MPDATA,ENTH,2,,4.53285756e8
MPDATA,ENTH,2,,1.2748e9
MPDATA,ENTH,2,,2.22519e9
MPDATA,ENTH,2,,3.3396e9
MPDATA,ENTH,2,,3.548547e9
MPDATA,ENTH,2,,3.548556e9
MPDATA,ENTH,2,,4.352e9
MPTEMP,,,,,,,,
MPTEMP,1,25.5
MPTEMP,2,160
MPTEMP,3,291.5
MPTEMP,4,477.6
MPTEMP,5,635
MPTEMP,6,698
MPTEMP,7,709
MPTEMP,8,720.3
MPTEMP,9,742
MPTEMP,10,761
MPTEMP,11,1000
MPDATA,MURX,2,,200
MPDATA,MURX,2,,190
MPDATA,MURX,2,,182
MPDATA,MURX,2,,161
MPDATA,MURX,2,,135
MPDATA,MURX,2,,104
MPDATA,MURX,2,,84
MPDATA,MURX,2,,35
MPDATA,MURX,2,,17
MPDATA,MURX,2,,1
MPDATA,MURX,2,,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,RSVX,2,,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,125
MPTEMP,3,250
MPTEMP,4,375
MPTEMP,5,500
MPTEMP,6,625
MPTEMP,7,750
MPTEMP,8,875
MPTEMP,9,1000
MPDE,RSVX,2
MPDATA,RSVX,2,,1.84e-7
MPDATA,RSVX,2,,2.72e-7
MPDATA,RSVX,2,,3.84e-7
MPDATA,RSVX,2,,5.12e-7
MPDATA,RSVX,2,,6.56e-7
MPDATA,RSVX,2,,8.24e-7
MPDATA,RSVX,2,,1.032e-6
MPDATA,RSVX,2,,1.152e-6
MPDATA,RSVX,2,,1.2e-6
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,3,,1
MPCOPY, ,3,4
TBCOPY,ALL,3,4
BLOCK,0.0185,0.0335,-0.0125,0.0125,0,0.0038,
BLOCK,-0.0225,0.0225,0.016,0.031,0,0.0038,
BLOCK,-0.0225,0.0225,-0.016,-0.031,0,0.0038,
BLOCK,-0.0335,-0.0185,-0.0125,0.0125,0,0.0038,
BLOCK,0.049,0.0745,-0.0075,0.0075,0,0.0038,
CSYS,1
FLST,3,4,6,ORDE,2
FITEM,3,1
FITEM,3,-4
VGEN, ,P51X, , ,0,90,0, , ,1
FLST,3,1,6,ORDE,1
FITEM,3,5
VGEN,10,P51X, , ,0,36,0, ,1
WPCSYS,-1,0
LOCAL,11,0,0,0,0.0048, , , ,1,1,
WPCSYS,-1,11,
CYL4, , ,0.0158,0,0.0745,360,0.0038
CSYS,0
LOCAL,20,0,0,0,0.0126, , , ,1,1,
WPCSYS,-1,20,
CYL4, , ,0,0,0.0795,360,0.001
CSYS,0
LOCAL,21,0,0,0,-0.0132, , , ,1,1,
WPCSYS,-1,21,
CYL4, , ,0,0,0.1,360,0.04
CSYS,0
ALLSEL,ALL
FLST,2,17,6,ORDE,2
FITEM,2,1
FITEM,2,-17
VOVLAP,P51X
NUMCMP,VOLU
ALLSEL,ALL
CM,_Y,VOLU
VSEL, , , , 16
CM,_Y1,VOLU
CMSEL,S,_Y
CM,_Y,VOLU
VSEL, , , , 16
CM,_Y1,VOLU
CMSEL,S,_Y
CSYS,1
WPCSYS,-1,0
CSYS,0
CSWPLA,30,1,1,1,
CM,_Y,VOLU
VSEL, , , , 16
CM,_Y1,VOLU
ALLSEL,ALL
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 2, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,14,6,ORDE,2
FITEM,5,1
FITEM,5,-14
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 1, , 2, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , , 15
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 3, , 3, 30
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , , 17
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 4, , 4, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
ALLSEL,ALL
FINISH
/RUN
FINISH
/PREP7
ALLSEL,ALL
VSEL,S, , , 1
FLST,5,4,4,ORDE,4
FITEM,5,1
FITEM,5,3
FITEM,5,6
FITEM,5,8
LSEL,S, , ,P51X
LESIZE,ALL, , ,5, ,1, , ,1,
ESIZE, ,5,
SMRT,6
SMRT,5
CM,_Y,VOLU
VSEL, , , , 1
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 2
FLST,5,4,4,ORDE,4
FITEM,5,13
FITEM,5,15
FITEM,5,18
FITEM,5,20
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 2
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 3
FLST,5,4,4,ORDE,4
FITEM,5,25
FITEM,5,27
FITEM,5,30
FITEM,5,32
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 3
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
ALLSEL,ALL
VSEL,S, , , 17
ALLSEL,ALL
ALLSEL,ALL
VSEL,S, , , 4
FLST,5,4,4,ORDE,4
FITEM,5,37
FITEM,5,39
FITEM,5,42
FITEM,5,44
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 4
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 5
LSEL,S, , , 186
ALLSEL,ALL
VSEL,S, , , 5
FLST,5,4,4,ORDE,4
FITEM,5,50
FITEM,5,52
FITEM,5,-53
FITEM,5,55
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 5
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 6
FLST,5,4,4,ORDE,4
FITEM,5,62
FITEM,5,64
FITEM,5,-65
FITEM,5,67
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 6
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 7
FLST,5,4,4,ORDE,4
FITEM,5,73
FITEM,5,75
FITEM,5,78
FITEM,5,80
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 7
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 8
FLST,5,4,4,ORDE,4
FITEM,5,85
FITEM,5,87
FITEM,5,90
FITEM,5,92
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 8
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 9
FLST,5,4,4,ORDE,4
FITEM,5,97
FITEM,5,99
FITEM,5,102
FITEM,5,104
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 9
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 10
FLST,5,4,4,ORDE,4
FITEM,5,110
FITEM,5,112
FITEM,5,-113
FITEM,5,115
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 10
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 11
FLST,5,4,4,ORDE,4
FITEM,5,122
FITEM,5,124
FITEM,5,-125
FITEM,5,127
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 11
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 12
FLST,5,4,4,ORDE,4
FITEM,5,133
FITEM,5,135
FITEM,5,138
FITEM,5,140
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 12
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 13
FLST,5,4,4,ORDE,4
FITEM,5,145
FITEM,5,147
FITEM,5,150
FITEM,5,152
LSEL,S, , ,P51X
ESIZE,0,5,
CM,_Y,VOLU
VSEL, , , , 13
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 14
FLST,5,4,4,ORDE,4
FITEM,5,157
FITEM,5,159
FITEM,5,162
FITEM,5,164
LSEL,S, , ,P51X
ESIZE,0,5,
FLST,5,4,4,ORDE,4
FITEM,5,157
FITEM,5,159
FITEM,5,162
FITEM,5,164
LSEL,S, , ,P51X
CM,_Y,VOLU
VSEL, , , , 14
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 15
FLST,5,16,4,ORDE,2
FITEM,5,169
FITEM,5,-184
LSEL,S, , ,P51X
LESIZE,ALL, , ,20, ,1, , ,1,
ESIZE,0,20,
CM,_Y,VOLU
VSEL, , , , 15
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 16
FLST,5,8,4,ORDE,2
FITEM,5,189
FITEM,5,-196
LSEL,S, , ,P51X
ESIZE,0,20,
CM,_Y,VOLU
VSEL, , , , 16
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
VSEL,S, , , 17
SMRT,6
SMRT,5
MSHAPE,1,3D
MSHKEY,0
CM,_Y,VOLU
VSEL, , , , 17
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/UI,MESH,OFF
FINISH
/SOL
FLST,5,4,5,ORDE,2
FITEM,5,95
FITEM,5,-98
ASEL,S, , ,P51X
NSLA,S,1
DSYM,ASYM,X, ,
ESEL,S,MAT,,3
FLST,2,3302,2,ORDE,2
FITEM,2,561
FITEM,2,-3862
BFE,P51X,JS,1,,2151887.4,, ,
ALLSEL,ALL
FINISH
/PREP7
FLST,3,1,6,ORDE,1
FITEM,3,16
VGEN,2,P51X, , , , , , ,1
CM,_Y,VOLU
VSEL, , , , 18
CM,_Y1,VOLU
CMSEL,S,_Y
CSYS,0
CM,_Y,VOLU
VSEL, , , , 18
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 2, , 5, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
VSEL,S, , , 18
FLST,5,8,4,ORDE,2
FITEM,5,189
FITEM,5,-196
LSEL,S, , ,P51X
FLST,5,8,4,ORDE,2
FITEM,5,189
FITEM,5,-196
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10, , , , ,1
ESIZE,0,10,
SMRT,5
CM,_Y,VOLU
VSEL, , , , 18
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/UI,MESH,OFF
VSEL,S, , , 18
ALLSEL,BELOW,VOLU
ALLSEL,BELOW,VOLU
NSEL,S, , , 11713
FINISH
/SOL
FLST,2,1,1,ORDE,1
FITEM,2,11713
SF,P51X,RDSF,0.68,1,
ALLSEL,ALL
FINISH
/PREP7
STEF,0.567E-07
TOFFST,273
RADOPT,0.10000000149,0.1E-01,0,1000,0.10000000149,0.10000000149
SPCTEMP,1,25
ESEL,S,MAT,,2
FINISH
/SOL
FLST,2,8873,2,ORDE,4
FITEM,2,3863
FITEM,2,-7963
FITEM,2,68735
FITEM,2,-73506
BFE,P51X,FVIN, ,1,
ALLSEL,ALL
MFAN,ON,MFSC
MFEL,_Z,1,2,3,4, , , , , ,
MFFN,_Z,
adolph002
我有一次也出现这个问题,最后重做发现有一个命令忘记输入了~
2013年5月28日
yuluoxuewu
我也想知道啊,我在做感应加热的本科毕设,也遇到这个问题,求解啊。。。而且我试过按ansys 11.0,12.0,13.0,都有这个问题啊。。。崩溃了
2012年4月17日
qiangqq
我也在做这个,也出现了这样的问题,请问一下你最后是怎么解决的?
2012年4月16日
