那位大神帮我翻译一段命令流,不胜感谢!
浏览:39272
*DIM,TIME_STEP,ARRAY,18,,
*VFILL,TIME_STEP (1),DATA,0.005,0.1,0.15,0.2,0.21,0.215,0.22,0.225,0.23,0.235
*VFILL,TIME_STEP(11),DATA,0.24,0.245,0.25,0.26,0.27,0.285,20,300
*DIM,SUB_STEP_NO,ARRAY,18,,
*VFILL,SUB_STEP_NO(1),DATA,2,2,2,3,3,3,3,3,3,3
*VFILL,SUB_STEP_NO(11),DATA,3,3,2,2,2,2,50,100
/COM,THERMAL
KEYW,PR_THERM,1
/FILNAME,THERMAL_ANALYSIS,1
/PREP7
ET,1,PLANE77
KEYOPT,1,1,0
KEYOPT,1,3,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,100
MPTEMP,3,150
MPTEMP,4,200
MPDATA,KXX,1,,47.1
MPDATA,KXX,1,,45
MPDATA,KXX,1,,43.95
MPDATA,KXX,1,,42.9
MPDATA,C,1,,464
MPDATA,C,1,,485
MPDATA,C,1,,495.5
MPDATA,C,1,,506
MPDATA,DENS,1,,7800
MPDATA,DENS,1,,7800
MPDATA,DENS,1,,7800
MPDATA,DENS,1,,7800
K,1,0.034,0,0,
K,2,0.034,0.1377,0,
K,3,0.034,0.20655,0,
K,4,0.034,0.2754,0,
K,5,0.034,0.28917,0,
K,6,0.034,0.296055,0,
K,7,0.034,0.30294,0,
K,8,0.034,0.309825,0,
K,9,0.034,0.31671,0,
K,10,0.034,0.323595,0,
K,11,0.034,0.33048,0,
K,12,0.034,0.337365,0,
K,13,0.034,0.34425,0,
K,14,0.034,0.35802,0,
K,15,0.034,0.37179,0,
K,16,0.034,0.392445,0,
K,17,0.034,0.416,0,
K,18,0.038,0.416,0,
K,19,0.038,0,0,
*DO,KKK,1,18
LSTR,KKK,KKK+1
*ENDDO
LSTR,19,1
AL,ALL
RECTNG,.038,.5,.3,.318,
AGLUE,1,2
LFILLT,24,22,.004,,
LFILLT,25,20,0.004,,
AL,18,26,27
AL,28,29,30
AADD,ALL
ESIZE,0.0025,0,
AMESH,ALL
LSEL,S,,,18,28,10
LREF,ALL,,,2,5,1,1
ALLSEL,ALL
SAVE
FINISH
/SOLU
IC,ALL,TEMP,190.7,
SFL,22,CONV,1094,,190.7,
SFL,24,CONV,1792.4,,190.7,
SFL,18,CONV,1792.4,,190.7,
*DO,LINE_NO,1,16
SFL,LINE_NO,CONV,8947.1,,190.7,
*ENDDO
ANTYPE,4
TRNOPT,FULL
LUMPM,0
OUTRES,ALL,ALL,
TIMINT,1
*DO,LOAD_STEP_NO,1,18
*IF,LOAD_STEP_NO,EQ,1,THEN
TIME,TIME_STEP(LOAD_STEP_NO)
AUTOTS,1
NSUBST,SUB_STEP_NO(LOAD_STEP_NO),,,1
KBC,1
LSWRITE,LOAD_STEP_NO,
*ELSEIF,LOAD_STEP_NO,LT,18,THEN
SFL,LOAD_STEP_NO-1,CONV,5513.6,,50,
AUTOTS,1
KBC,1
*ENDIF
*IF,LOAD_STEP_NO,EQ,18,THEN
AUTOTS,1
KBC,1
*ENDIF
*ENDDO
LSSOLVE,1,18,1,
FINISH
/POST1
SET,LAST
PLNSOL,TEMP,,0,
