急!!RedHat下安装哈工大下的ANSYS13_LINUX64报错求助!!
浏览:134237 回答:2
各位,有没有人在Redhat里装过哈工大下的Ansys13.0_LINUX64的?我在Linux下用Wine生成License后,启动License manager报错,如下:
Dec 05, 2011 10:27: Attempting to start the ANSYS, Inc. License Manager...
This may take a few seconds; please be patient...
Start the ANSYS, Inc. License Manager status:
The license manager failed to start.
** It is possible that it may require more time to fully start up **
You may examine the ANSYS Licensing Interconnect debug log file and the
ANSYS FLEXlm debug log file (by clicking the 'View Status/Diagnostic Options'
button) for more information or possible errors. Additionally, you can reference
the Troubleshooting section in the ANSYS, Inc. Licensing Guide for more details.
查看 FLEXlm debug log信息如下:
Dec 05, 2011 10:23:
CONTENTS OF THE ANSYS FLEXLM DEBUG LOG FILE:
(Path: /usr/ansys_inc/shared_files/licensing/license.log)
10:17:33 (lmgrd) -----------------------------------------------
10:17:33 (lmgrd) Please Note:
10:17:33 (lmgrd)
10:17:33 (lmgrd) This log is intended for debug purposes only.
10:17:33 (lmgrd) In order to capture accurate license
10:17:33 (lmgrd) usage data into an organized repository,
10:17:33 (lmgrd) please enable report logging. Use Flexera Software, Inc.'s
10:17:33 (lmgrd) software license administration solution,
10:17:33 (lmgrd) FLEXnet Manager, to readily gain visibility
10:17:33 (lmgrd) into license usage data and to create
10:17:33 (lmgrd) insightful reports on critical information like
10:17:33 (lmgrd) license availability and usage. FLEXnet Manager
10:17:33 (lmgrd) can be fully automated to run these reports on
10:17:33 (lmgrd) schedule and can be used to track license
10:17:33 (lmgrd) servers and usage across a heterogeneous
10:17:33 (lmgrd) network of servers including Windows NT, Linux
10:17:33 (lmgrd) and UNIX. Contact Flexera Software, Inc. at
10:17:33 (lmgrd) http://www.flexerasoftware.com for more details on how to
10:17:33 (lmgrd) obtain an evaluation copy of FLEXnet Manager
10:17:33 (lmgrd) for your enterprise.
10:17:33 (lmgrd)
10:17:33 (lmgrd)
10:17:33 (lmgrd)
10:17:33 (lmgrd) The license server manager (lmgrd) running as root:
10:17:33 (lmgrd) This is a potential security problem
10:17:33 (lmgrd) and is not recommended.
10:17:33 (lmgrd) Failed to open the TCP port number in the license.
有哪位遇到过这样的问题,并解决的吗?是否可以告诉我解决方法?万分感谢。
jiangok8
什么 情况!!!!!!!!!
2012年2月18日
frank0521
晕。没有人遇到过这样的问题吗
2011年12月5日
