ansys中license manager服务不能开启————FLEXlm: not running
浏览:115299 回答:1
其他两个服务都能running,只有这个不行,偶尔能running也不能打开ANSYS。
之前一周都没问题,现在不能用,发愁死了。
错误代码:ansys FLEXlm Debug log file中写到:“
pid 7932
17:37:17 (lmgrd) The TCP port number in the license, 1055, is already in use.
17:37:17 (lmgrd) Possible causes:
17:37:17 (lmgrd) 1) The license server manager (lmgrd) is already running for this license.
17:37:17 (lmgrd) 2) The OS has not "cleared" this port since lmgrd died.
17:37:17 (lmgrd) 3) Another process is using this port number (unlikely).
17:37:17 (lmgrd) Solutions:
17:37:17 (lmgrd) 1) Make sure lmgrd and all vendor daemons for this
17:37:17 (lmgrd) license are not running.
17:37:17 (lmgrd) 2) You may have to wait for the OS to clear this port.
17:37:17 (lmgrd) Retrying for about 5 more minutes
17:37:36 (lmgrd) Still trying...
17:37:54 (lmgrd) Still trying...
17:38:12 (lmgrd) Still trying...
17:38:30 (lmgrd) Still trying...
17:38:48 (lmgrd) Still trying...
17:39:06 (lmgrd) Still trying...
17:39:24 (lmgrd) Still trying...
17:39:42 (lmgrd) Still trying...
17:40:00 (lmgrd) Still trying...
17:40:18 (lmgrd) Still trying...
17:40:36 (lmgrd) Still trying...
17:40:51 (lmgrd) Failed to open the TCP port number in the license.“
望高手前来支援呀!
漩涡鸣人
没人能解决这个问题吗?
2011年12月23日
