在abaqus中,出现下面问题,怎么办?多谢指教
浏览:121046 回答:2
The user defined normal of the material orientation of 22 elements, as defined in *ORIENTATION, is orthogonal to the GASKET, SHELL or MEMBRANE normal direction. Check input data. The elements have been identified in element set ErrElemUserNormMatOrient.
