新人求助
浏览:164370 回答:6
小弟大四保研苦逼自学ansys。。。 找了个案例试试就是不成功 求大神解救!!
计算分析模型如图1-1 所示, 习题文件名: beam
NOTE:要求选择不同形状的截面分别进行计算。
1-1梁的计算分析模型
梁截面分别采用以下三种截面(单位:m):
矩形截面: 圆截面: 工字形截面:
B=0.1, H=0.15
R=0.1
w1=0.1
w2=0.1w3=0.2,
t1=0.0114t2=0.0114t3=0.007
1.1进入ANSYS
程序 AnsysED 6.1 Interactive change the working directory into yours input Initial jobname: beamRun
1.2设置计算类型
ANSYS Main Menu: Preferences select Structural OK
1.3选择单元类型
ANSYS Main Menu: Preprocessor Element TypeAdd/Edit/Delete… Add… select Beam 2 node 188
OK (back to Element Types window)Close (the Element Type window)
1.4定义材料参数
ANSYS Main Menu: Preprocessor Material Props Material Models StructuralLinearElasticIsotropicinput EX:2.1e11, PRXY:0.3 OK
1.5定义截面
ANSYS Main Menu: Preprocessor Sections Beam Common Sectns分别定义矩形截面、圆截面和工字形截面:矩形截面:ID=1,B=0.1H=0.15 Apply →圆截面:ID=2,R=0.1 Apply →工字形截面:ID=3,w1=0.1w2=0.1w3=0.2t1=0.0114t2=0.0114t3=0.007OK
1.6生成几何模型
ü
生成特征点
Modeling Create Keypoints In Active CS→依次输入三个点的坐标:input:1(0,0),2(10,0),3(5,1)OK
ü
生成梁
ANSYS Main Menu: Preprocessor Modeling Create Lines lines Straight lines 连接两个特征点,1(0,0),2(10,0) OK
1.7网格划分
Meshing Mesh Attributes Picked lines OK 选择: SECT:1(根据所计算的梁的截面选择编号);Pick Orientation Keypoint(s):YES拾取:3#特征点(5,1) OKMesh Tool Size Controls) lines: Set Pick All(in Picking Menu) input NDIV:5 OK (back to Mesh Tool window) Mesh Pick All (in Picking Menu) Close (the Mesh Tool window)
1.8模型施加约束
ü
最左端节点加约束
ANSYS Main Menu: Solution Define Loads Apply Structural Displacement On Nodes pick the node at (0,0) OK select
UX, UY,UZ,ROTX
OK
ü
最右端节点加约束
ANSYS Main Menu: Solution Define Loads Apply Structural Displacement On Nodes pick the node at (10,0) OK select UY,UZ,ROTX OK
ü
施加y方向的载荷
ANSYS Main Menu: Solution Define Loads Apply Structural Pressure On Beams Pick All VALI:100000 OK
1.9 分析计算
Solve Current LS OK(to close the solve Current Load Step window) OK
1.10 结果显示
ANSYS Main Menu: General Postproc Plot Results Deformed Shape… select
Def + Undeformed
OK (back to Plot Results window) Contour Plot Nodal Solu select: DOF solution, UY, Def + Undeformed , Rotation, ROTZ ,Def + UndeformedOK
1.11 退出系统
ANSYS Utility Menu: File
Exit Save EverythingOK
在1.9分析计算时就弹出这个对话框
我是按着他的步骤一步一步来的。。不知道哪里出错了。。 第一次弄ansys 跪求大神啊!!!
(6)
JUVEXIONG
继续求大神
2012年9月20日
JUVEXIONG
求救。。。。。
2012年9月18日
JUVEXIONG
我也是在学啊。。。
2012年9月18日
yibuhui
好复杂啊 小弟实在学不会啊 郁闷中 求指点
2012年9月18日
JUVEXIONG
回复 2楼ANSYSUser1999的帖子
点1限制6个自由度 点2限制UX UZ ROTX ROTY以后结果还是不行。。。
2012年9月18日
ANSYSUser1999
1. 请标明一下坐标方向X, Y, Z
2. 这是悬臂梁吧,固定端的六个只有度都要限制
2012年9月18日
