求助,solver报错
浏览:187466
Wall Heat Transfer Coefficient written to the results file uses |
| "Wall Adjacent Temperature" for the bulk temperature. If you want |
| to override the bulk temperature then set the expert parameter |
| "tbulk for htc = <value>"
这个问题该怎么解决啊?求高手解决,谢谢啦!!!
