waring of ls-dyna
浏览:73504
*** WARNING *** CP = 18.720 TIME= 19:12:24
Shape testing revealed that 1 of the 80537 new or modified elements
violate shape warning limits.
我把一个单元类型为solid 186 单元的带有0.2mm倒圆角的块,用5级精度自由划分,求解时出现上述问题,请问该怎么解决?看不懂这个警告。
