system error code 144
浏览:153278 回答:1
各位朋友好,我从网上下载移动热源的例子,含子程序,错误终止,显示The executable C:\ABAQUS\6.10-1\exec\standard.exe aborted with system error code144. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code
到网上查了,试了重新保存模型。也没解答。希望大神帮忙
胡秋斌
你好啊,我遇到了跟你相同的问题,请问你后来是怎么解决的啊?能帮我一下吗?求助啊
2017年3月26日
