新手求指点!!在做例题的时候总是出现错误
浏览:55890 回答:1
Thermal contact has been defined between the surfaces ASSEMBLY_PAD-DOWN and ASSEMBLY_DISK-UP, but no temperature degrees of freedom associated with the surface ASSEMBLY_PAD-DOWN.
刹车盘热分析那个例题,我查了好几遍了眼睛都瞎了,求求你告诉我可能在哪个步骤的哪个地方可能的错误吧!!求求你了!只要你认为可能错的都告诉我
