亲,请问ABAQUS安装时验证没有通过的问题。谢谢!祝大家端午节快乐!
浏览:186835 回答:2
大家好,首先祝大家端午快乐!
在此,小弟向大家请教一个 ABAQUS二次开发时软件的安装问题。谢谢!
本人安装的软件版本为: ABAQUS 6.9.3+Microsoft Visual Studio 2008(英文版)+IVF10.1.034
在验证之前,已经设置运行 Abaqus时自动调用执行ifortvars.bat,即:在Abaqus\Commands\abq693.bat文件中,在@ echo
off下插入了下面这行命令:
"C:\Program Files\Intel\Compiler\Fortran\10.1.034\IA32\bin\ifortvars.bat"
但是在验证时,出现:
Setting environment for using Microsoft Visual Studio 2008 X86 tools。
请问大家该问题该怎么解决?谢谢!
附验证文件为:
Running system requirement checks.
Requirement: Windows XP, Windows Server 2003 Standard Edition, or Windows
Vista
Product: All Abaqus Products
Status: Pass - Found Microsoft Windows XP Professional Service Pack
3 (Build 2600).
Requirement: Microsoft Visual C++ 8.0 (.NET 2005) or 9.0 (.NET 2008)
Product: Abaqus make utility with C++
Status: Fail - Unable to locate or determine the version of a C++
compiler on this system. If Microsoft Visual C++ 8.0 (.NET
2005) is installed on this system, please load the
vcvars32.bat file before running Abaqus.
Requirement: Intel Fortran Compiler 9.1 or 10.1
Product: Abaqus make utility with Fortran and Abaqus with user
subroutines
Fortran compiler on this system. If Intel Fortran is
installed on this machine, please load ifortvars.bat before
running Abaqus.
Requirement: Internet Explorer 6.0, Mozilla 1.2, Firefox 1.0.1, or
greater
Product: Abaqus Documentation
Status: Pass - Found Internet Explorer 6.0.2900.5512
Making D:\Temp\verify. All verification files will reside in this directory.
Abaqus/Standard
...PASS
Continuing...
Abaqus/Standard with user subroutines
...INFORMATION
System requirements were not met. Verification
procedure will be skipped. However, user subroutines
can be run using a precompiled library set by the
variable usub_lib_dir. For more information please
see the section 3.2.2 of Abaqus Analysis User's
Manual.
Continuing...
Abaqus/Explicit (single precision)
...PASS
Continuing...
Abaqus/Explicit (double precision)
...PASS
Continuing...
Abaqus/Explicit with user subroutines (single precision)
...INFORMATION
Manual.
Continuing...
Abaqus/Explicit with user subroutines (double precision)
...INFORMATION
Manual.
Continuing...
Abaqus/Viewer
...PASS
Continuing...
Abaqus/CAE
...PASS
Continuing...
Geometry Translator for CATIA V4
...PASS
Continuing...
Geometry Translator for CATIA V5
...PASS
Continuing...
Direct Geometry Import for CATIA V5
...PASS
Continuing...
Geometry Translator for I-DEAS
...PASS
Continuing...
Geometry Translator for Parasolid
...PASS
Continuing...
Geometry Translator for Pro/ENGINEER
...PASS
Continuing...
SolidWorks Associative Interface
...PASS
Continuing...
Abaqus/AMS
...PASS
Continuing...
Abaqus Interface for MSC.ADAMS
...PASS
Continuing...
Abaqus/Standard parametric studies
...PASS
Continuing...
Abaqus/Explicit parametric studies
...PASS
Continuing...
Abaqus/Design
...PASS
Continuing...
Abaqus Interface for Moldflow
...PASS
Continuing...
...INFORMATION
Continuing...
...INFORMATION
Continuing...
Abaqus make utility with object code
...INFORMATION
Continuing...
Abaqus scripting interface
...PASS
Continuing...
Abaqus analyses using parallelization
Running thread-based parallel with 2 cpu(s)
Abaqus/Explicit domain-level parallel
...PASS
Abaqus/Standard direct solver
...PASS
Continuing...
Abaqus/Foundation
...PASS
Continuing...
Abaqus noGUI (CAE/Viewer)
...PASS
Continuing...
Clean-up...
Verification directory D:\Temp\verify has been deleted.
neu_ral
谢谢您!
2013年6月24日
neu_ral
谢谢您!
2013年6月13日
