提交错误代码5
浏览:74033 回答:1
在调用子程序时出现错误提示,请问哪位知道这个问题的原因是什么The executable d:\SIMULIA\Abaqus\6.11-1\exec\standard.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job ww aborted due to errors. 望高手解答不胜感激~
challenge
碰到同样的问题了,纠结啊
2014年4月23日
