钢筋混凝土柱温度场分析出现的错误报告,求救!
浏览:180744
错误报告如下
1,Elements of type dc1d2 cannot be used as underlying elements to define an element-based surface.
2,No surface facets are generated for surface assembly__pickedsurf88.
3,Element 14 instance gujin-1 cannot be used as an underlying element to define a surface in this current release. This element will not be considered as part of surface assembly__pickedsurf88.
Element 28 instance gujin-1 cannot be used as an underlying element to define a surface in this current release. This element will not be considered as part of surface assembly__pickedsurf88.
Element 42 instance gujin-1 cannot be used as an underlying element to define a surface in this current release. This element will not be considered as part of surface assembly__pickedsurf88.
Element 56 instance gujin-1 cannot be used as an underlying element to define a surface in this current release. This element will not be considered as part of surface assembly__pickedsurf88.
