ABAQUS错误信息
浏览:142167 回答:1
The volume of 288 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.
Analysis Input File Processor exited with an error.
求大神指教???给出具体方法
求大神指教???给出具体方法
