很无语的出现了一个warning,求大神们点拨一下啊
浏览:64893
Warning 4023 (INI+23)
43004 redundant prescribed motion boundary conditions
on rigid bodies have been automatically disabled.
slave surface of interface = 1
type = a 3
surface timestep = 1.200E-06
controlling slave node ID = 41
part ID of slave node = 1
current minimum time step = 1.200E-06
The LS-DYNA time step size should not exceed 1.200E-06
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
出现这样的warning是需要把网格化得更细呢,还是把输出步数增加,还是需要其他的,求大神们点拨一下
