求帮忙,求帮忙
浏览:112855 回答:1
想用ADAMS做钢丝绳的仿真,用轴套力的方法做,可是不太懂宏命令,谁能给提供一份钢丝绳仿真的宏命令程序。多谢
EdwardLi
defaults model model_name=.shengzi
variable create variable_name=ip integer_value=1
while condition=(ip<300)
marker create &
marker_name = (eval(".shengzi.part_"//ip//".MARKER_1"//ip+1000)) &
location = 0.0,(eval(ip*50)),0.0 &
orientation = 0d, 90.0d, 90.0d
marker create &
marker_name = (eval(".shengzi.part_"//ip+1//".MARKER_1"//ip+2000)) &
force create element_like bushing &
bushing_name = (eval(".shengzi.bushing_"//ip)) &
adams_id = (eval(ip)) &
i_marker_name = (eval(".shengzi.part_"//ip//".MARKER_1"//ip+1000)) &
j_marker_name = (eval(".shengzi.part_"//ip+1//".MARKER_1"//ip+2000)) &
damping = 1, 1, 1 &
stiffness = 5.9346e4,5.9346e4 ,5.9346e4 &
tdamping = 1 , 1 , 1 &
tstiffness = 5,5 ,5
variable modify variable_name=ip integer_value=(eval(ip+1))
end!while
variable delete variable_name=ip
之前看到的八哥大佬的,自己看着改改,基本上bushing都可以用这个搞
2021年6月18日
