提交运算出现2 elements have small or zero length
浏览:131622
做一个环梁节点的滞回曲线分析,job check的时候出现错误“2 elements have small or zero length,The elements have been identified in element set ErrElemLenSmallNegZero.”在result中高亮显示
ErrElemLenSmallNegZero但无任何结果,想问一下各位如何通过check。
