求助,2D面板命令,skin与ruled的区别
浏览:31360 回答:1
RT,想知道这两个命令通常什么情况下用
songshilong123
The Ruled panel allows you to create surfaces and/or meshes of plate elements from nodes, lines, and/or line segments, in any combination. Nodes in the mesh being created are placed on a surface created on a linear basis between the two sets of selected entities.
The Skin panel allows you to create a skin surface and/or mesh from a set of lines.
Note: The Skin panel is for lines that are stacked next to each other. If lines form a closed loop, use the Spline panel.
我理解为,前者必须设置两组,后者随便,但后者的线必须不是封闭的,封闭的用spline
2014年2月22日
