新手求救 1073741819
浏览:165655 回答:8
在做三维模型时总是计算不了,出现以下内容:
The executable standard.exe aborted with system error code
1073741819
. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.做二维的模型就没问题,按照有些大神的建议,拔了一个内存条,还是不行。
跪求大神解救啊!
检查一下边界条件是否设置正确 我的是边界条件选择的是网格节点 而不是参考点 他报错代码和你一样 我将边界条件选择到节点上后 就没有问题了
