ABAQUS 连续墙与土(急急急 请大家帮忙!!!)
浏览:173571 回答:1
警告:A geostatic procedure with maximum displacement tolerances is supported only for continuum elements with pore pressure degree of freedom and the corresponding stress/displacement continuum elements. In general, the use of other elements with this procedure may lead to poor convergence or no convergence of the analysis.
错误:too many attempts !
出现这样的问题,怎么解决,求大家为小弟解答,不胜感激
kuangzi
2014年3月6日
