job时出现以下状况如何解决:
浏览:38779 回答:1
job时出现以下状况如何解决:
The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
taozui3285
新手求教,pre.exe aborted with system error code 1073741819
根据上述帖子里,引述的一段google解决办法,意思是说,最好不要用2根内存条,否则有可能在软件寻址的时候出现上述问题!(1、降低节点数量;2、使用单根大容量内存条;或者3,、按照上述帖子里的,换个版本试试)
检查一下:安装路径和工作路径中都不要有中文字符
2014年3月7日
