四面体网格划分问题
浏览:89924 回答:3
四面体网格划分在帮助中有这么一句话:
Other element configurations generated in this panel are: hexahedra六面体l, wedge楔形, and pyramids锥体金字塔. These elements are typically generated when the user needs boundary layer type meshes on certain areas of the volume surface.
不是四面体吗?怎么还能出现楔形和锥形呢?
float trias/quads
Matches the node locations of the volume elements with those of the surface mesh, but the connectivity may be modified to produce a better mesh. Normally, this results in some tetra faces going across tria diagonals. Base quad surface elements are split into two trias
fixed trias/quads
Matches the node locations of the volume elements with those of the surface mesh. It guarantees the connectivity of the tetras with the trias. Use this option whenever you need to match other components to the resulting volume mesh, or when you need to generate layers composed of pentas/hexas.
这些话又怎么理解?
第三附图中的anchor node什么意思
songshilong123
是这样吗? wedge五面体、pyramids五面体 不是这样嘛
2014年3月17日
sixnight1
至于锚点(anthor node)一般我就认为就是顶点啦,就是生成这个网格的点啦
2014年3月17日
sixnight1
对啊,四面体是两种啊,一种是契型(那个字打不来)就是上面两个点下面两个点十字交错,
锥型,就是上面一个点下面三个点。
2014年3月17日
