求高手指点。定义了刀具的约束,怎么还有这个问题
浏览:152448
做三维铣削时出现这个错误,一直没解决,求高手指点
Degree of freedom 11 and at least one of degrees of freedom 1 thru 6 must be active in the model for *dynamic temp-disp. Check the procedure and element types used in this model.
并附上出错的input文件,望高手指点
