在adams/car仿真中出现报错
浏览:73925 回答:1
报错如下:
Static equilibrium analysis has not been successful.
The maximum number of iterations 25, has been reached.
For the last attempted iteration:
The equation with the largest error was model.y.bkl_z_ng.field Comp = 4 Error = 95125.427397
The variable receiving the largest increment was model.y.gel_strut_lower Comp = 5 Delta = 980665.000000.
因为急着解决希望高手及时帮助。不胜感激!
jdqcgl
楼主,解决了吗?我也遇到了此问题,望指导
2014年8月28日
