关于ADAMS钢丝绳建模的一个问题,初学者来请教下各位前辈
浏览:29654 回答:1
这是我建立的模型:
就是在左上角的套筒添加动力,使绳子绕右上角的轮子提起重物
问题:每次进行仿真的时候都会弹出下面这段“WARNING”,不过仍然可以继续进行仿真。后处理后,我将仿真的数据跟一些论文的数据对比了一下,其中发现了一段曲线(左上角套筒的主轴的角加速度)非常的奇怪(图PO在下面),根据“WARNING”我也大概猜测是在“钢丝绳”弯曲的部分的轴套力出现了什么问题。不过具体是什么问题我就想不到了,这个问题困扰了我几天了,不知如何下手,所以想请教一下各位前辈,到底是那部分出错了导致这样的问题,学习一下。谢谢了。
异常的曲线:
相比于下面的曲线,它在7.5秒的曲线上下波动很奇怪
论文中的正常的曲线:
下面是每次仿真按钮按下后,弹出的WARNING:
WARNING: During the construction of simi.bushing_48 an angle measure is created
between two markers, simi.part_48.MARKER_11048 and simi.part_49.MARKER_12048, which do not have
a near-parallel axis of rotation.
I[1.000000, -0.000000, 0.000000] J[0.923880, -0.382683, 0.000000]
WARNING: During the construction of simi.bushing_49 an angle measure is created
between two markers, simi.part_49.MARKER_11049 and simi.part_50.MARKER_12049, which do not have
I[0.923880, -0.382683, 0.000000] J[0.707107, -0.707107, 0.000000]
WARNING: During the construction of simi.bushing_50 an angle measure is created
between two markers, simi.part_50.MARKER_11050 and simi.part_51.MARKER_12050, which do not have
I[0.707107, -0.707107, 0.000000] J[0.382683, -0.923880, 0.000000]
WARNING: During the construction of simi.bushing_51 an angle measure is created
between two markers, simi.part_51.MARKER_11051 and simi.part_52.MARKER_12051, which do not have
I[0.382683, -0.923880, 0.000000] J[-0.000000, -1.000000, 0.000000]
WARNING:
The Reconcile Acceleration-Force has detected a singular Jacobian matrix.
This problem may be caused by:
(a) A constraint equations that became almost redundant, e.g., the model
is at a singular configuration or at a bifurcation point.
(b) A massless PARTS in the model.
The Sparse Solver has detected row 1219 has zero length (during the symbolic pivot selection).
The corresponding equation is: Part/207 X Force
A minimization algorithm will be used to find a solution on the
projected constraint manifold.
WARNING:
The Integrator has detected a singular Jacobian matrix.
The Calahan Sparse Solver has detected an unexpected singularity at row 6072.
The corresponding equation is: Contact/Contact/Model X Force
aersitong24
虽然我不知道答案,但是也正在研究这个钢丝绳方面问题,如果可以,加我qq 493131698 今后有问题一起讨论
2014年6月20日
