submit中的警告,求是忽略还是怎么解决?我是新手
浏览:83605
The option *boundary,type=displacement has been used; check status file between steps for warnings on any jumps
prescribed across the steps in displacement values of translational dof. For rotational dof make sure that there are
no such jumps.All jumps in displacements across steps are ignored.
