钢筋混凝土非线性分析
浏览:187479
*** FATAL *** CP = 491.856 TIME= 11:23:10
The supplied nonlinear material properties produced an incorrect
material tangent matrix. Please check your TB input carefully. A
very small yield stress may cause this failure.
在做钢筋混凝土非线性分析,遇到这种问题,不知道哪里错了,帮帮忙哈~
