ansys ,流固耦合 ,模态分析
浏览:120433
请问,油罐流固耦合,做模态分析。
显示"Master degree of freedom not allowed on slave degree of freedom in coupled set.
Coupled set number 811 First node= 98657 Slave node= 126403 Degree of
freedom= UX
Move Master to first node. "
这是怎么回事?怎么解决呀。谢谢
