abaqus错误求助
浏览:105724 回答:2
Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other constraint including mpcs, rigid bodies, etc.
colin998
有过约束,节点约束的自由度重复。
2014年9月7日
ssarlen
rbe2共用了某个节点。
2014年9月6日
