平面网格问题,求大神指导
浏览:187232 回答:5
利用ICEM划分平面非结构网格,如图所示
但是导入FLUENT中检查网格质量出现如下警告
WARNING: Mesh check failed.
To get more detailed information about the mesh check failure
increase the mesh check verbosity via the TUI command
/mesh/check-verbosity.
Fluent can also try to fix the mesh check problems via the TUI command
/mesh/repair-improve/repair.
Mesh Quality:
Orthogonal Quality ranges from 0 to 1, where values close to 0 correspond to low quality.
Minimum Orthogonal Quality = 0.00000e+00
Warning: minimum Orthogonal Quality below 0.01.
Maximum Aspect Ratio = 1.00000e+00
Fluent can try to improve the mesh quality via the TUI command
/mesh/repair-improve/improve-quality
求大神指教是什么问题????
Mesh Quality:
求大神指教是什么问题????
