abaqus做个简单的裂纹扩展出现了问题??
浏览:14348 回答:10
错误:Too many attempts made for this increment
Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists.
警告:9 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
There are 3 unconnected regions in the model.
注:abaqus 6.11
文件如下 还请大神告知!
注:abaqus 6.11
文件如下 还请大神告知!
你好,你的问题解决了吗
