ANSYS WORKBENCH CFX双向流固耦合求解失败
浏览:12486 回答:6
小弟最近用ANSYS WORKBENCH CFX双向流固耦合,求解失败,这个错误出现了N+次了,崩溃了,希望各位大神帮助,,提示如下:This run of the CFX-14.5 Solver started at 08:56:43 on 16 Feb 2015 by
user Administrator on PC201308051525 (intel_xeon64.sse2_winnt) using
the command:
"D:\Program Files\ANSYS Inc\v145\CFX\bin\perllib\cfx5solve.pl" -batch
-ccl runInput.ccl -fullname "Fluid Flow CFX_019"
Setting up CFX Solver run ...
| Processing ANSYS Input File (Running CCL2MF) |
Created
C:\Users\Administrator\Desktop\practice\15-2-14\15-2-14_pending_tasks\-
dp0_CFX_Solution_1\Fluid Flow CFX_019.ansys\ANSYS.mf
| Starting ANSYS Solver |
| An error has occurred in cfx5solve: |
| ANSYS Solver terminated unexpectedly with return code 3840 |
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager. |
This run of the ANSYS CFX Solver has finished.
the command:
Created
| Warning! |
不知道你解决了没有,我也遇到了一样的问题,我显示的错误信息的溢出
