修改inp文件后导入出错
浏览:7355
ABAQUS错误提示:BAQUS error the ratio of deformation speed to wave speed exceeds 1.0
更改方法:加*SECTIONCONTROLS,NAME=SC,DISTORTIONCONTROL,LENGTHRATION=0.1或者YES也可以,加在MATERIAL前面;或 加*DIAGNOSTICS,DEFORMATION SPEED CHECK=OFF;或者加*DIAGNOSTICS,CUTOFFRATIO=RATIO(具体数值)
按照提示更改inp:
** Constraint: Constraint-1
*Rigid Body, ref node=_PickedSet18, elset=PART-1-1.tumo
** Constraint: Constraint-2
*Rigid Body, ref node=_PickedSet12, elset=aomo-1.aomo
*End Assembly
*Amplitude, name=Amp-1
0., 0., 1., 1.
*Diagnostics,deformation speed check=off
** MATERIALS
*Material, name=banliao
*Density
7.8e-09,
*Elastic
210000., 0.3
*Plastic
但更改后导入提示:Error in job 3-24-onestep-xiugai-1: Unknown keyword "diagnostics,deformationspeedcheck=off". The keyword may be misspelled, obsolete, or invalid.
求高手指导,不胜感激!!!
按照提示更改inp:
*End Assembly
0., 0., 1., 1.
** MATERIALS
*Density
7.8e-09,
*Elastic
210000., 0.3
*Plastic
求高手指导,不胜感激!!!
