求助高手帮我看看为什么仿真不出磁感线
浏览:10143 回答:1
/title, 3-D Transformer Harmonic Response, 1/4 symmetry
/vie,1,2,-1,3
/pnu,mat,1
/num,1
pi=acos(-1)
! *** Model parameters
a_core=0.040 ! core cross-section width
w_core=0.100 ! overall core width
h_core=0.100 ! overall core height
r1_coil=0.025 ! inner radius, both coils
r2_coil=0.029 ! outer radius, both coils
p_coil=0.020 ! height, primary coils
s_coil=0.030 ! height, second coils
d_dmn=0.020 ! depth of surrounding domain
esz1=a_core/8 ! element size, components
esz2=esz1*2 ! element size, surrounding domain
mu_core=100000 ! core permeability
! *** Primary coil
Np=100 ! # of turns
Rp=10 ! DC resistance (ohms)
care_left=(r2_coil-r1_coil)*p_coil ! cross-sectional area
volu_left=pi*(r2_coil**2-r1_coil**2)*p_coil ! volume
Vp=220 ! voltage (V)
! *** Secondary coil
Ns=200 ! # of turns
Rs=Rp*(Ns/Np)**2 ! DC resistance (ohms)
care_right=(r2_coil-r1_coil)*s_coil ! cross-sectional area
volu_right=pi*(r2_coil**2-r1_coil**2)*s_coil ! volume
R=1e3 ! resistance attached to the secondary coil
frqncy=50 ! operating frequency (Hz)
symm=2 ! symmetry factor
/nopr
! *** Geometry
/PREP7
vsel,none ! core
bloc,-w_core/2,w_core/2,-h_core/2,h_core/2,-a_core/2,0
cm,scrap1_v,volu
vsel,none
bloc,a_core/2-w_core/2,a_core-w_core/2,a_core/2-h_core/2,h_core/2-a_core/2,-a_core/2,0
bloc,w_core/2-a_core,w_core/2-a_core/2,a_core/2-h_core/2,h_core/2-a_core/2,-a_core/2,0
cm,scrap2_v,volu
cmse,s,scrap1_v
cmse,a,scrap2_v
vsbv,scrap1_v,scrap2_v
cm,core_v,volu
vatt,2,2,2
wpcs,-1,0 ! left coil ESYS
wpof,,h_core/2-a_core/2
wpro,,-90
cswp,11,1
wpcs,-1,0 ! right coil ESYS
wpof,,a_core/2-h_core/2
wpro,,-90
cswp,12,1
csys
vsel,none ! left coil
wpcs,-1,11
cyli,r1_coil,r2_coil,0,-p_coil,0,180
vatt,3,3,3,11
vsel,none ! right coil
wpcs,-1,12
cyli,r1_coil,r2_coil,s_coil,0,0,180
vatt,4,4,4,12
alls
cm,keep_v,volu
wpcs,-1,0 ! surrounding domain
vsel,none
bloc,-w_core/2-d_dmn,w_core/2+d_dmn,-h_core/2-d_dmn,h_core/2+d_dmn,-a_core/2-d_dmn,0
cm,scrap_v,volu
cmse,all
vsbv,scrap_v,keep_v,,dele,keep
cmse,u,keep_v
cm,air_v,volu
vatt,1,1,1
alls
vplo
! *** FE model
et,1,236 ! air
mp,murx,1,1
et,2,236 ! core (laminated, non-conducting)
mp,murx,2,mu_core
et,3,236,2 ! left primary coil
mp,murx,3,1
r,3,care_left,Np,volu_left,0,1,0 ! left coil data
rmore,Rp,symm
et,4,236,2 ! right secondary coil
mp,murx,4,1
r,4,care_right,Ns,volu_right,0,-1,0 ! right coil data
rmore,Rs,symm
! *** Mesh
numm,kp,1e-8,1e-8
esiz,esz1
vsel,s,mat,,3,4
vmes,all
vsel,s,mat,,2
vswe,all
vsel,s,mat,,1
msha,1
esiz,esz2
vmes,all
alls
! *** Boundary conditions and loads
asel,s,ext ! flux parallel exterior
csys
asel,u,loc,y
da,all,az
vsel,s,mat,,3 ! left primary coil
alls,belo,volu
cp,1,emf,all
cp,2,volt,all
nd_p=ndnext(0)
alls
vsel,s,mat,,4 ! right secondary coil
alls,belo,volu
cp,3,emf,all
cp,4,volt,all
nd_s=ndnext(0)
alls
d,nd_p,volt,Vp
! *** Circuit
et,5,124,0 ! resistor connected to the secondary coil
r,5,R
*get,nmax,node,,num,max
n,nmax+1,0,h_coil/2
type,5
real,5
e,nd_s,nmax+1
d,nmax+1,volt,0 ! ground
csys
eplo
fini
! *** Solution
/solu
antype,harmonic
harf,frqncy
solve
fini
liusongoku
只有二维分析可以查看磁感线分布。三维只有b的矢量和云图
2015年4月15日
