出现这错误怎么解决呀The geometry of 1 elements is too distorted
浏览:16538 回答:1
The geometry of 1 elements is too distorted. Check the nodal coordinates or node numbering on elements identified in element set ErrElemDistorted.
19 nodes have dof on which velocity/displacement/acceleration/base motion etc. constraints are specified simultaneously. The nodes have been identified in node set ErrNodeBCRedundantDof.
Analysis Input File Processor exited with an error.
cyqcyqcyqcyq
请大神帮忙啊
2015年5月15日
