beam4 和 shell41 接触怎么处理?
浏览:5434
参加结构设计竞赛,用桐木条和油性纸做高层结构,想用beam4和shell41 进行受力分析,结果计算不出来。错误代码:
*** WARNING *** CP = 11.357 TIME= 21:29:48
Structural elements without mid nodes usually produce much more
accurate results in quad or brick shape.
*** WARNING *** CP = 11.934 TIME= 21:29:49
There are 220 small equation solver pivot terms.
*** ERROR *** CP = 11.950 TIME= 21:29:49
The value of UY at node 274 is 1.337944562E+14. It is greater than the
current limit of 1000000. This generally indicates rigid body motion
as a result of an unconstrained model. Verify that your model is
properly constrained.
命令流在附件,求指教
