ANSYS利用生死单元做裂纹分析出现的问题
浏览:4258 回答:1
我现在在做压痕试验的裂纹仿真,我的思路是:加载求解后,得到被压材料的单元的应力值,将大于临界应力值的单元杀死,再进行加载,反复几次后得到最终结果,被杀死的单元就作为裂纹可以显示出来。
想问一下这种方法可以吗?
另外我在这么做的过程中,发现一个问题:将单元杀死后,总体再加载求解时,会出现下面的问题:
One or more elements have become highly distorted. Excessive
distortion of elements is usually a symptom indicating the need for
corrective action elsewhere. Try incrementing the load more slowly
(increase the number of substeps or decrease the time step size). You
may need to improve your mesh to obtain elements with better aspect
ratios. Also consider the behavior of materials, contact pairs,
and/or constraint equations. If this message appears in the first
iteration of first substep, be sure to perform element shape checking. 我压头和被压材料的网格划分的很精细了,而且增加子载荷步也没有用。
想问一下这种方法可以吗?
