abaqus错误求解
浏览:11689
第一个是job计算时出现的error是 150 nodes have missing section thickness definitions.The nodes have been identified in node set ErrElemMissingNodeThick.的error 第二个是定义stress时出现的错误框
我要做的问题时abaqus使用手册里面的2.1.5
