接触模型的问题
浏览:9276
我做的是接触分析,其他条件和接触关系都设置好了,但是出现的问题是17 nodes have incorrect normal definitions. The nodes have been identified in node set ErrNodeIncorrectNormal.
6 nodes have incorrect normal definitions. The nodes have been identified in node set ErrNodeIncorrectNormal.
Analysis Input File Processor exited with an error.
请问给位高手应该怎么改??
