Abaqus 定义裂纹扩展方向 crack extension direction时的问题
浏览:15305
Abaqus中定义crack时可以用Normal to crack plane来间接定义裂纹扩展方向(crack extension direction),表达式为 q= t x n. q为crack extension direction, t为crack front的切线方向, n为定义的normal。 求教 t的方向是如何确定的?在建模时在什么地方可以定义?对于一个曲线上一个点,切线方向有两个。选择相反方向的 t的结果差别很大。
附上Abaqus Documentation中的片段:
Specifying the virtual crack extension direction
You must specify the direction of virtual crack extension at each crack tip in two dimensions or at each node along the crack line in three dimensions by specifying either the normal to the crack plane, Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图1, or the virtual crack extension direction, Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图2.
If the virtual crack extension direction is specified to point into the material (parallel to the crack faces), the J-integral values calculated will be positive. Negative J-integral values are obtained when the virtual crack extension direction is specified in the opposite direction.
Specifying the normal to the crack plane
The virtual crack extension direction can be defined by specifying the normal, Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图3, to the crack plane. In this case Abaqus/Standard will calculate a virtual crack extension direction, Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图4, that is orthogonal to the crack front tangent, Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图5, and the normal, Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图6. As shown in Figure 11.4.2–1, Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图7 for a three-dimensional crack; for a two-dimensional crack, we simply have Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图8 and Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图9. Specifying the normal implies that the crack plane is flat since only one value of Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图10 can be given per contour integral.
Figure 11.4.2–1 Typical focused mesh for fracture mechanics evaluation.
Abaqus 定义裂纹扩展方向 crack extension direction时的问题的图11
